Where to redo a Targa top
Local trim shop or interior shop? Seems to me I saw an ad in one of the P mags advertising a cheap rehab of the targa top. Any help here?
Old 05-28-2010, 06:33 AM
brads911sc's Avatar
I wouldnt send my Targa to either of those choices. Dan at Cars Inc in NJ. He did mine. http://carsinc-nj.com/index.htm
There are only a couple shops in the entire country that have the parts. Many are NLA at the dealer.
Worth sending it to NJ. It comes back better than it left the factory. Cant say that about most trim shops. Plan on the Stage 3 ($895) if its never been redone.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 05-28-2010, 06:37 AM
HarryD's Avatar
Ther are several that advertise in the mags.
Like brads911sc says, I, too, would send mine to Dan Pechtel at Cars, Inc in NJ. He has helped me with my top in the past with parts and advise.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-28-2010, 07:15 AM
Dan did mine...
there is a reason he has done many..
Rika
Old 05-28-2010, 07:48 AM
Weekend Mechanic
vulcan300's Avatar
Dan at Carsinc did mine as well. His service is a good one. There is also another guy in Colorado that does good work and has a pretty rigorous process for the rebuild and would be worth talking to (I think his name is Doug Brown?). I can dig up the info for the Colorado guy if you like. Regardless of which guy you use you will spend about 1000 for a high quality rebuild. If you take it to another type of shop that doesn't specialize in this type of work and does not understand the complex construction of the tops you will be very unhappy with what you get back. A poorly rebuilt top will result in incredibly loud wind noise coming from the top at Highway speed.
J
86 911 Carrera Targa
Old 05-28-2010, 07:57 AM
The expert in the west is Dave Brown
That's all he does. EXCELLENT!
He did mine - like new - probably better than new.
Targa Tops by Dave Brown
(303) 499-0110
6186 Gale Dr, Boulder, CO 80303
Old 05-28-2010, 08:35 AM
Weekend Mechanic
vulcan300's Avatar
I was working from memory on Mr Brown's name. I've read through the description of the process he has developed for restoration and it is impressive. It's probably as close as you'll get to a new top from the factory based on the approach he takes when tearing down and rebuilding the tops.
Old 05-28-2010, 09:17 AM
