Brembo Brake Questions
Does anyone no if these part# will fit on a 1989 911 with 15''7&8'' rims
Part number on right front caliper 996.351.429 and left rear 996.352.426.
and if so where can i get the proper adapters as well.Thanks any help would help
A man who dares to waste one hour of time has not discovered the value of life.......
Much Respect
Old 02-28-2010, 09:54 PM
Northern Motorhead
wildcat077's Avatar
Those appear to be Big Reds from a Carrera 4S or a 996 TT 01-05 and they will fit on 17 inch wheels or larger,You will also need the matching rotors and an expensive adaptor kit ...
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-01-2010, 02:02 AM
Rennsport Systems out of Portland, OR sells a Brembo kit that will fit (barely) inside certain 16" Fuchs. I have 16x8s on the rear and the 16x7s from the 944 Turbo on the front. Even then, you must grind down the bolts on the Brembos to get adequate clearance. It is no big deal for the brakes, but grinding away at that expensive red paint brings tears to one's eyes. Guards Red touch up paint is a near perfect match, however.
Rich Kessel
79 R.o.W. 911 SC
Old 03-01-2010, 06:28 AM
Northern Motorhead
wildcat077's Avatar
89 Cab,
I have a direct bolt on kit for your car,excellent condition 2003 986 front and 996 rear calipers repainted in Brembo red and a brand new never installed complete TRE adaptor kit with all the hardware,stainless brake lines, along with New Porterfield R4S brake pads.This is a complete plug and play kit that can be used with your stock rotors not an Ebay bag of different parts thrown together.
Pictures available on request !
Cheers !
Phil
Cheers
Phil
Old 03-01-2010, 12:39 PM
Northern Motorhead
wildcat077's Avatar
Forgot to mention...
This kit will fit with 15 and 16 inch Fuchs wheels !
Phil
Cheers
Phil
Old 03-01-2010, 12:40 PM
I may of screwed up if 7 & 8 are from a 944,then I should have 6 & 7,so will they fit then..........I wish I had 7 & 8.
Much Respect
Old 03-01-2010, 08:05 PM
Wildcat,send me a pic on your kit and $$$$$$......
Much Respect
Old 03-01-2010, 08:08 PM
Northern Motorhead
wildcat077's Avatar
89 Cab,
I posted it yesterday in the classifieds under TRE Boxster brake conversion,if you want
more details send me a PM with an email address and i'll suppy more photos ...
Cheers !
Phil
Cheers
Phil
Old 03-02-2010, 04:59 AM
