Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
donnmaddy
Musty odor coming from ac vents
I replaced ac compressor, cleaned hoses, new dryer, new o-rings and new expansion valve and now I have cold air coming from vents but now I also have a musty odor coming from vents. I need help getting rid of this smell. Thanks
Old 03-02-2010, 07:31 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
You may have a problem at the bottom of the Evap box - not draining.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'15 Ram EcoDiesel
Old 03-02-2010, 07:42 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
What is the year of your 911?
I agree, you will need to verify that the drain hole is not plugged.
This is done by checking for water under the car after A/C use.
On occasions, the drain may be only partially plugged, which may cause some confusion.
To clear the drain hole, use a very flexible item as to not damage the evaporator.
The drain hole is slightly visible at the resistor pack located on the passenger's side floorboard.
Also, if the compressor does not have the proper on/off cycling time, the evaporator will freeze up and produce the issue you have detected.
Good luck,
Gerry
You may pm me.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-02-2010, 07:57 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Bland
RWebb's Avatar
there's a fungus among us
besides the above, you will want to clean all the duct work with a bleach solution - use a push/pull rod with a swab you dip into 1/4 bleach with some detergent in water
this can be very important for the health of those riding in the car - it can be a medical issue, not merely an obnoxious odor
Old 03-02-2010, 10:38 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
donnmaddy
Thaks very much, I will see if I can find the drain hole tonight and unplug it and then clean air ducts. By they my 911 is a 1988 cab.
Old 03-02-2010, 03:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Wurth makes an A/C mold killer spray that is very effective. Mold tends to grow on your evaporator. You spray this into your return ducting while ac is running then let sit for a few hours. This of course after making sure your drains are clear.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-02-2010, 03:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
