How to refinish turn, brake lt. lenses?
What’s the best way to repaint the black edge trim on Euro front and rear lenses? Dip, brush, spray? Currently, the edges are without paint. Thanks
Sherwood
Old 03-21-2020, 02:31 PM
Darkly-Noon's Avatar
I just used gloss black paint for plastic models (oil based) that I got at a hobby store, brushed on. Worked pretty well, And I used a plastic polish for the exterior side of the lens.
1980 911SC Targa
Old 03-22-2020, 06:11 AM
Keep in mind many plastic lenses have some level of UV protection in the outer layers. Our tail lights are old and may not, but think of new headlights. When you buff them down to clean them up you removed the worn out UV layers. The problem then is that the lens has no protection any more, and so it often deteriorates much faster. To prevents this, once they are cleaned up you might want to hit them with some protection. That could be ceramic coat, or you could get a UV resistant clear coat. The benefit there is that later on, if you need to clean them up you are buffing down the clear, not the plastic. Just a thought.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-22-2020, 07:31 AM
Ctopher's Avatar
I used flat black model paint and novus plastic polish to refurbish my tail lights. If your worried about UV, I would use something like CarPro Dlux on the lenses for durability and UV protection
CTopher
Old 03-22-2020, 07:47 AM
DerkPerk's Avatar
Very timely post for me. I just went to change a turn signal bulb and realized I need to do this too.
Old 04-02-2020, 08:48 PM
Schloer2's Avatar
Thanks for the great COVID project - easy, cheap, and rewarding.
Old 04-03-2020, 05:13 PM
COVID project? Related? Did I miss something? Details?
Sherwood
Old 04-03-2020, 09:29 PM
joefrantz's Avatar
I pretty much did the same as everyone as far as painting. I used good ol Testors black enamel, brushed on the inside.
I also did my front lenses, which presented another problem. There were a number of stone chips in the lenses, and the chips on the front side, made it look like the paint was
chipped off, even though the paint was on the inside of the lens. I ended up gently planing the surface of the chipped lenses with a single edged razor blade to remove the erupted "crater edges" of the stone chips, then wet sanding in stages from about 800 to 2000 grit. I polished using a plastic compound and buffing wheel.
Before painting, I stripped the old paint with oven cleaner.
The wet sanding and buffing made a huge difference. I did this a while ago, circa 2004. You could do the buffing part today with one of the headlight polishing kits and a drill. No need for the buffing wheel and rouge.
Joe Frantz
73 911 T
Old 04-04-2020, 12:40 AM
Schloer2's Avatar
Sherwood
Sherwood - I just meant this was a great project to do while stuck at home under the COVID stay-at-home orders.
Old 04-04-2020, 04:14 AM
Duh. Thanks for the clarification.
Old 04-04-2020, 06:38 PM
