-   -   Oxygen sensor nut and (http://forums.pelicanparts.com/porsche-911-technical-forum/52967-oxygen-sensor-nut.html)
pwm74 11-26-2001 05:47 PM
Oxygen sensor nut , electrical connectors
Does anybody know where to get the nut welded into the exhaust for the oxy sensor.
I also need a three wire water proof PLUG of the oxy,
does anyone make a universal one.
Also does anyone know were to get the washers for motor mounts.
these are very difficult items to get
danielt 11-26-2001 07:30 PM
Check Autozone/Napa/local parts store. They should be able to supply generic 3 wire O2 sensor with nut to be welded to exhaust manifold. It is typically recommended to install within 18" of the cylinder head. I think with the 3 wire O2 sensors there is a little more flexiblity, though.
Daniel
sammyg2 11-26-2001 07:42 PM
Any decent muffler shop has the O2 sensor bungs, and can weld them in for around $20 or so.
finadict 11-26-2001 08:14 PM
Try B&b exhaust, they make an extension cable for the o2 sensor and they have the bung for the sensor..... Pat
