Boot Seal
Hi, I have replaced the boot seal after rebuilding my SC.
This has quite a bit of tension on the lid, and holds it away from the body when closed. It appears to be a poor design, with a lip which I think faces the wrong way to prevent the ingress of water.
I am quite disappointed after having a nice set of boot carpets which keep getting wet.
Am I expecting too much?
I cannot find any threads about it on the forum
Old 09-30-2012, 03:04 AM
tazzieman's Avatar
A picture would help decide if it is somehow installed wrongly.
What is the source for your seal?
If not the installation, adjust the latch at the front.
Remove 2 plastic plugs and have at it with an Allen key !
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 09-30-2012, 04:49 AM
