-   -   How to run new fuel and return lines? (http://forums.pelicanparts.com/porsche-911-technical-forum/52968-how-run-new-fuel-return-lines.html)
scca_ita 11-26-2001 06:52 PM
Should I run these in the tube? Will the lines fit safely in the tube with shifter?
jhale356 11-26-2001 09:26 PM
New lines should fit just fine. There is a large "tube" on the left side that keeps the fuel lines out of the center of the tunnel. I couldn't find replacement factory or aftermarket lines and ended up using steel brake lines.
John
'69 911
scca_ita 11-26-2001 09:43 PM
Brake lines seem a littler small? I was told to try 3/8" hard line that is flexible like brake line.
jhale356 11-26-2001 09:54 PM
If memory serves me, the main line is 8mm and the return line is 6mm. Brake lines come in both 5/16 and 3/8. I think the 5/16 is close to 7mm, but you could mic them to be exact. We used 5/16 for the return line. We converted a T to an S and the T had no return line. Email me if you want more details.
John
'69 911
