'71 2.2 Distributor Problem
Are there any aftermarket distributors for a 2.2l to eliminate the points? My distrib. cam shaft moves up 5mm if I pull it, and I am having engine shutdowns because of erratic point operation.
Or , is rebuilding the dist. something I can easily do? |
Look into 2.7 Carrera dizzy. New about $280 Call Pelican first
1 Attachment(s)
Art,
It sounds as if your snap-ring under the felt plug wasn't replaced, or maybe it came loose. It should be an easy fix to the 5 mm play problem. There is quite an extensive discussion of distributor disassembly and cleaning in the following thread: http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=5432&highlight=distribu tor+lube |
| All times are GMT -8. The time now is 03:14 AM. |
