2002 996 C4S
jcsjcs's Avatar
1 Short Valve Cover Stud?
Hey all -
Adjusted my Valves this weekend and put the Valve covers back on.
One of the Exhaust (bottom) Valve Cover Studs is a lot shorter than the others. The tip of the stud does not stick out of the nut - but I was able to torque it up just like the other studs.
Is this unusual / a problem?
I did not notice if it was short before I took them off.
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 07-26-2010, 04:18 AM
KNS KNS is offline
It is not unusual for a stud to come out when when removing the nuts, they shouldn't but it happens. For some reason you had one replaced with a shorter stud. If it is on there snug and not leaking, I wouldn't worry about it. Next valve adjustment buy the correct length stud and replace.
Kurt
Old 07-26-2010, 06:27 AM
