Where is the Auxiliary air valve located (when facing the engine)? and is there any way to test it.
Yesterday, while driving my 83 died in traffic; the car burped a little and the idle when down to nothing. unstrapping the air cover, i could hear the pop off snap down. got back into the car and it started just fine. after driving about a mile, i idle increased to about 1800 and stayed there. coming out of work yesterday evening, started the car and notice the idle speed to oscillating until warm. after warm, idle increased to about 1800 and stayed there and adjusting the idle has no affect. According the Jim William's CIS overview, these are the things associated with the Auxiliary air valve not close. hence the leadoff question
Brad 1983 911 Cabriolet (daily driver) 2000 ML 320 (Shared by teenagers) 2005 Pilot (Wife's) |
Somatic Negative Optimist
AAV doesn't open or close; the AAR does.
The AAR can be checked for correct operation but I suggest that you get yourself more familiar with CIS and all its components. Do you have the Bentley SC Repair Manual? If the pop-off valve snapped down when you opened the air filter cover, it may be installed wrong. Post a picture of the pop-off so we can see if it's correct. Do you have the Bentley?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Check for a vacuum leak too.
82 911SC Targa (05 Boxster S ) gone, but not forgotten 87 Suzuki GSXR-1100 1953 MG TD Mk II |
regarding the pop-off; I will post a picture this evening. Last night in researching this issue, I came accross a photo of a pop-off value. Again, late night but it the photo suggested the value opens towards the front of the car. Mine open towards the rear of the car. The PO installed it or had someone install it
I have seen this suggestion on this forum and in some other publications. The question I had is does that involve some sort of tool or merely a visual inspection?
If you suspect a vacuum leak, you will have lots of help here in tracking it down. A bit of patience and perseverance will pay off. Keep us informed of what you find.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 03-04-2010 at 11:43 AM.. |
the hinge should be towards you when looking at it.
if that is ok, it may be the decel valve.
CIS troubleshooting..........for vacuum leak/s.
Brad, The way you descibed the condition of your car, I would bet that you have unmetered air. One very simple way to determine if you have unmetered air is to remove the oil filler cap when the engine fully warmed up and running. Once you removed the oil cap, you'll notice an RPM drop. If you don't get any change in RPM (idle speed going down), you got unmetered air going into the system. The second option to locate your vacuum is to pressurize your system and look for air leak/s. Concentrate in areas where there are connections like rubber hoses, boots, rubber seals, etc. The air box seams, pop valve seat, brake vacuum line, etc. are also candidates for vacuum leak. There are too many spots where vacuum leak could occur. Not being able to find one does not mean you don't have any. So stop the guess work and do the investigation wisely. Using propane, carburator cleaner, starter fluid, etc. are not as reliable and dependable than using compressed air. Check the AAR located near the intake manifolds #4 & #6 (passenger-side ). I doubt this is the culprit. Keep us posted. Tony |
I have continued searching this topic in this forum and have found more information to get me up to speed. I will be checking hoses as described above in in other posts. I appreciate the help and support.
Great, not the case; however, this will need to after I resolve the high idle issue. Too bad I can't rotate the photo and have the car follow suit.
besides it being installed backwards, it appears a little loose as in the proxy is given way. I can wiggle it with a little force; however, I would not characterize it as about to fall out either.
check the air filter, see if it shows signs of it hitting it.
While the car was running, the idle was about 1200 (less than the normal 1800 since this issue started).
I took a small screw driver and slightly pry opened the pop-off and the idle increased a little bit. I did a couple more time with the same result. when i stopped the idle remained at 1800 until I turned the car off. In my previous post response, I mentioned that the pop off valve is "glue" in but not rock solidly. if a pop off valve is installed properly, should I be able to move it at all? if I elect to redo the install of the pop off, what proxy should I use?
If that doesn't improve your idle problem, follow the suggestions for finding vacuum leaks. Be patient and thorough. It's a PITA, but it is necessary to have a well running CIS. Let us know what you do and what you find. Good luck. edit: You posted while I was typing. Most here use two part JB Weld for epoxy. Not sure of the brand of urethane, but if you type "urethane" into the search function, a recent thread should appear where it is mentioned by brand name, I think, as I remember reading about it just a few days ago. BTW, I just noticed your location--I'm just a bit up the coast from you. Feel free to contact me directly if you have any questions. Shoot me a PM and I'll give you the phone number.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 03-05-2010 at 07:05 AM.. |
I also found this comment on the Epoxy: Comments: What is the best epoxy to use brand name to fix the pop off valve in position April 27, 2009 Followup from the Pelican Staff: I think a standard hardware store extra strength epoxy would do the trick. I've used that before with excellent results. Loctite is a great brand, I've also used Devcon with good success too. - Wayne at Pelican Parts
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
I suspected the pop-off from the start. Aside from being installed the wrong way, the picture makes me think that it was done pretty sloppy and that's most likely the reason for wrong air entering the system. You can try to re-glue the valve but, if the hole is over-sized, it may not work. Meaning a new box. The pop-off valve has to be tight so that the mixture can be set correctly. Do that first, then check for vacuum leaks per suggestions like oil cap etc. and only when there are no vac leaks, set the mixture and correct idle. Let us know.
Just a follow-up. Inspired by Gunter's post, I took another look at your pic of the valve. It looks like it is not even sitting flush on the bottom of the airbox, but rather resting on the ribs. If so, that will definitely be leaking from the way it was installed. If the hole for the valve is not too large as Gunter mentioned, then before you reinstall the valve correctly, file down the ribs so the base of the valve is flush with the airbox. Then apply the adhesive and seat the valve firmly.
When I was examining it yesterday, it appears that the valve is sitting on the ribs but did not immediately tie sitting on the ribs to air leaking in. if the PO used silicone to attach the valve, there is a good chance the silicone filled the gaps between the ribs--until now. All good speculation and I will confirm when I take it apart this weekend. Your observation and comments were timely and helpful. Right now, I am praying that the hole was properly sized as I am not looking for (time and $$) to replaceing the airbox.
