Sunroof wind deflector install help
Hi All,
My car was always missing the sunroof wind deflector so I just installed it.
Problem is, it jams the sunroof. If the roof is closed and i try to open it, as soon as the roof passes the deflector, it pops up and jams the roof before it is far enough back to clear the parts that are spring loaded. Also if i try to close the roof once open, the deflector doesn't get pushed low enough for the roof the clear it.
Any ideas?
Thanks,
Adam
_____________________
'73 RSR Interpretation
Old 03-08-2010, 05:42 PM
I'm familiar with the later sunroofs only in theory. It seems you may have a part missing because something on the roof should be depressing the spring as it moves over it and hold it down as it moves back. I looked at the PET diagram but I couldn't see anything but, again, I don't know what to look for. I do know the earlier cars had plastic clips or lift pieces that attached to the inside leading edge of the roof that pushed down the wind deflector, but that was set up differently. Do you have plastic lift pieces? See the link below for a picture:
http://www.pelicanparts.com/techarticles/911_sunroof_repair/Pic11.JPG
Don't know if that's your problem but I'm sure someone who has dealt with this issue will help out.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-08-2010, 06:09 PM
Monza_dh's Avatar
Had the same issue a few yrs ago, schematic below. I thinks its #49? I got one used for my '88 and they are plastic.
dC AutomotiveOver 140,000 square feet of new and used Porsche parts
Here's a thread showing the white plastic piece that clips to the underside of the sun roof:
Sunroof repair project (cable repl)
$35 and a six pack to my name.....
'88 Diamond Blue Carrera CE 3.4-SOLD
Old 03-08-2010, 07:06 PM
