Polygraphite arm bushing Question
Why is there two different numbers on the bushings 2558 rear 2557 front?
After a search could not find any reason for this. They seem identical. |
that might be just the mold or lot number.
they should be interchangable, unless they have started doing someting to the durometer of the fronts vs. rears. Bill K |
you want to throw them away anyway...
use new rubber of the polybronze items |
Check the OD, I think they are slightly different from front to back.
Purchased the rubber bushings on ebay $38.00.
Elepahnt Racing Rubber is 5 times that price. Are they worth it?
is a flat 6 Porsche motor worth the extra cost compared to a V-6 from a Kia?
I was trying to figure out why Elephants rubber was $225 for 4 front bushings. I guess they have to recoup R&D costs. What is the verdict on the $38 ones from ebay? They appear to be made by Uro.
Note the install video halfway down the page. |
I'll take my chances. At least I took your suggestion not to use the PG bushing! I don't use smiles if I did I'd put one HERE. |
I do not know about the rubber quality per se.
In general, tho, I see CV joint boots that last only a year or two before disintegrating - these are usually made in China and are often sold on flea-bay... Considering the amount of on-your-back labor involved, I would do it once - not set up a situation where I might have to do it twice. I do look forward to seeing what people say a few years down the road - it will be an interesting experiment. |
The big picture is for front AND backs. For ER rubber, you are looking at $295, while for ER PB you are looking at $575. That means I will probably go with ER rubber, and because I am a lazy bastard and don't want to have to remember greasing suspension bits.
Anybody else chime in on the Ebay bushings?
for the price difference, I went with neatrix from weltmiester and made my own install tool, (though it wasn't billet aluminum) and saved about $130
Bill K |
watch the videos, that's why they're better. No affiliation but i will be buying those pretty soon. |
Go ahead and install the poly-graphite. Then we can all look for your thread asking how to stop the squeaking.
I used to use poly bushings in a race car.. I never heard them squeak.. :)
Seriously, pack them with a waterproof synthetic grease and they will not squeak... buncha elitists on here.. ;) If you wanna be sure thread them for a great fitting.. I doubt it would hurt to have a small hole in them... plenty of material.. when you are on a budget you gotta do what ya gotta do. |
| All times are GMT -8. The time now is 04:21 AM. |
