pud pud is offline
Porsche Crest Porsche 911s 1975
Hi , i have a problem with my revcounter, the needle seems to flick up and down on its own , does anybody know the cause of this , thanks,
Old 03-10-2010, 09:52 AM
dtw dtw is offline
GAFB
Clean and adjust your points, then verify the grounds on the ignition circuit.
Several BMWs
Old 03-10-2010, 10:26 AM
pud pud is offline
Porsche Crest porsche 911s 1975
hi thanks for the repy. could it be a faulty coil causing the trouble ,
Old 03-10-2010, 10:31 AM
90% of the time it's your points as dtw has pointed out. It could also be a cracked distributor cap or other things - but in general with these cars, it's most likely something really simple like the points. So go after the easy stuff first.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 03-10-2010, 10:36 AM
dtw dtw is offline
GAFB
Yep, could be a coil going out, but check the easy/free/common stuff first. You can inspect the cap/rotor too, while you're cleaning & adjusting the points. I'll echo the above, 90% of time it is the points. One time I did discover a failed ground connection on the igntion harness, though.
Several BMWs
Old 03-10-2010, 10:52 AM
pud pud is offline
OK. i have a new distributor cap and rotor on there , i also changed the ignition leads and fuel filter as ive been getting a jolty engine when pulling away, does this car have a condenser ,
Old 03-10-2010, 11:10 AM
dtw dtw is offline
GAFB
Jolty near idle? Swinging tach?
Points!
No condenser.
Several BMWs
Old 03-10-2010, 11:12 AM
pud pud is offline
THE car always starts well and the engine idles well and revs up good, but when i pull away it sometimes is jolty but as i change up the gears and get into 4th gear it runs really well at higher speed
Old 03-10-2010, 11:21 AM
