MBruns for President
JeremyD's Avatar
Koni front shock - bilstein compatibility
I have Koni shocks on my new to me 1974 - they are the adjustable kind. Can I change out the insert to a bilstein insert? is there compatibility?
Old 03-11-2010, 06:26 AM
RichHawk's Avatar
nope.
(Disclaimer, this is just what I read here: a bushel of internet knowledge is worth about one ounce of personal experience)
For the fronts: Koni for Koni only. Bilstein and Boge are interchangeable. If you really want Bilstein in the front, you need to trade out the entire front strut assembly and spindle.
Richard
Old 03-11-2010, 06:47 AM
JeremyD's Avatar
Thanks -
Old 03-11-2010, 07:32 AM
Chuck Moreland's Avatar
What type of struts do you have? It's the strut that is important, not the insert.
Black - boge
red - koni
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-11-2010, 09:08 AM
JeremyD's Avatar
They are red -
I have the same torsion bars as my cabriolet had - 22mm
This car does not have your elephant racing poly bronze a-arm bearings like the cabriolet (but it does have replacement poly graphite)
The only difference is the weight of the two - cab was probably #400 lbs heavier
AND the cab had bilstein front (HD) this (1974 Wide Body SC/Carrera Suspension) car - with the Koni adjustable is VERY bouncy over even small imperfections. Even with the koni adjusted all the way down.
Got any other suggestions?
Old 03-11-2010, 09:16 AM
