Help with Fuchs part number
Anyone know the offsets for 16x7"&8" Fuchs with the following part numbers?
7's - 911 361 020 44 8's - 911 361 020 45 |
My Bruce Anderson Performance Handbook shows your fuch part numbers as 15" wheels, not 16".
7x15 911 361 020 (41) 23.3 mm offset 8x15 911 361 020 (42) 10.6 mm offset I don't know if the last two numbers make a difference but according to BA, the 16" wheels have p/n 911 362..... Anyone else with knowledge of fuch p/n's? You can also e-mail the p/n's to wheel enhancements. I did that once and they got back to me quickly with offset info. Good luck. |
Actually, Don, I would have thought you were right at first, but looking around I show that those rims were 16" rims available thru '84 at that time the part #'s were superceded.
911 361 020 44 16x7 on the rear offset 23.3mm superceded by 911 362 115 00 911 361 020 45 16x8 on the rear of turbos thru '84 offset 10.6mm superceded by 911 362 117 00 Hope this helps :) |
| All times are GMT -8. The time now is 04:13 PM. |
