Mishap: Drilled exhaust stud too far
Has anyone had the experience of drilling too far into the head while trying to extract a broken exhaust stud? If so, what are the options for fixing the issue? 1979 911sc 3.0
Pic? Did you drill into anything important?
Sounds like you may have drilled into the fins and if so, should not represent a problem
No problem there. Drilled nicely on center, too.
