1986 Carerra Odometer
Hi All,
For some reason my 86 Carrera's ODOMETER stopped working.. What could be the problem? I have not driven the car for a long time. Speedometer is working just fine.
Thanks in advance...
Mauricir
Romuald Mauricio
Old 03-12-2010, 09:15 AM
Odometer Gear replacement for Electronic Speedometers (long)
Old 03-12-2010, 09:21 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by mauricir View Post
Hi All,
Mauricir
There is an excellent post by Thrasher on this site.
However, if you chose to remove the needle, it must be done very, very carefully,
as a broken needle shaft will cost you $$$$$.
After reading most of the posts, I chose to have the repair performed at a shop.
$120.00 including the odometer gear.
Check other posts.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-12-2010, 09:32 AM
I'm here to cause trouble
jimbauman's Avatar
Pull the speedo out of the hole and see if any wires at the back are disconnected...
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 03-12-2010, 09:34 AM
+1 on the broken odo gears - they are fragile plastic.
I have found the definitiave way to avoid breaking the gears, because even careful pressing on the reset pin with the car not moving at all will still break them:
After my second set of gears went in, I have not pressed the reset once in over 100k miles and my odo still works!
Hope this helps,
Chuck.H
'89 TurboLookTarga, 311k miles
Old 03-12-2010, 11:04 AM
175K911's Avatar
+2 on the broken odo gears. They get brittle with age. I send mine to North Hollywood Speedo to be repaired.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 03-12-2010, 11:38 AM
dshepp806's Avatar
NH tech confirmed this odo reset notion being the cuprit of the failure to be that of mythology. There may exist a relational failure yet it's not said to be the actual "cause" of the odo failure (breaking teeth)......
Just an FYI.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-12-2010, 12:11 PM
French Import
zippy_gg's Avatar
In my odo the gear has completely disintegrated. I replaced it as I was in there to put in white faceplate (flame suit on!).
But I never had any issue with breaking an odo on any of my former vehicles by pressing the rest button while at a stand-still.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 03-12-2010, 01:11 PM
