Smart quod bastardus
fredmeister's Avatar
front strut bump stops still required?
I was sending my Bilstein front strut inserts out for rebuild and noticed that the original rubber bumper donuts inside the strut housing had been disintegrated into litttle pieces. Possibly age or likely impact damage from bottoming out the front struts but anyway here is my question:
I have been told that the original style bump stops are no longer required as they are internal to the strut inserts that are being currently remanufactured/rebuilt. IS THIS TRUE?
I have not seen a replacement offered for the Bilstein insert on this Pelican site where I order all my parts so am wondering if this is a true statement. I am scepticle and want to make sure before I reinstall the inserts without new bump stops and in the event I do bottom out the suspension I dont damage the insert.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-01-2010, 09:18 AM
Did some more digging and cannot find a supplier for these bump stops anywhere.
This is becoming a hassle finding out information. Bilstein in NC cannot answer my questions either and waiting on a call back from Bilstein CA which is rebuilding my inserts currently.
Anyone can point me to a supplier of these bump stops so i can order a new set?
Old 03-02-2010, 08:54 AM
I picked up new ones and the roll pin thru Elephant racing Prod.
they had everthing and resonable too.
Lorne M.
83 SC
Old 03-02-2010, 10:44 AM
You need new rubber bump stops as they are not internal on 911 shocks.
Bilstein has them so ask them to send a pair when they return your shocks.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-02-2010, 01:05 PM
Steve, I check my car with revalve Bilstein insert without bump stop, just insert and dust cover, is it ok to run like this, also how to torque the insert to camberplate, impact wrench? use normal wrench will turn the nuts and insert shaft together. thanks
Old 03-12-2010, 12:33 AM
You need those bumpstops to protect the shock from internal damage. If they bottom out, even momentarily, the piston at the end of the shock rod strikes the floating piston that separates the oil from the nitrogen chamber and they will mix. Instant dead shock.
I use an impact gun to set the 55 lbs-ft, but I've been doing this for a long time and I know my equipment very well.
You can use a set of channel locks (or big vise grips) to hold the concave washer and torque it to spec.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-12-2010, 12:50 AM
redranger's Avatar
I just replaced my front boge inserts with bilstein sport struts. The bump stops from the boge's did not fit on the bilsteins so I didn't use any bumpstops.
My understanding is that the front inserts for Bilstein sport/HD have internal stops. If they were needed, wouldn't Bilstein include them??
86 Targa
Old 03-12-2010, 04:59 PM
You mean bilstein insert to boge strut or boge insert to bilstein strut?my case is billstein insert to boge strut no bump stop . Anyway thanks pls let me know, I just finish doing camber king ,balljoint , corner weight and alignment , if take apart for bump stop and do it again is real PITA.
Old 03-12-2010, 07:48 PM
SP2 SP2 is offline
SP2's Avatar
Uh oh. Can someone post a pic of the bump stop you are talking about. I can't remember if mine had any. Thanks!
Old 03-12-2010, 09:14 PM
redranger's Avatar
Sorry, should have been clearer. Bilstein insert going into boge strut...no bump stop. I had a sachs insert from the PO that had the bump stops. I've been searching around and can't find anything official about bilstein inserts having internal stops, but that seems to be the unofficial consensus if you trust the internet
86 Targa
Old 03-13-2010, 04:25 AM
Totally agree, especially with or without internal stops, even different technican have different theory, and stil l waiting Bilstein call back.
Old 03-13-2010, 07:58 AM
