-   -   Computer Module repair (http://forums.pelicanparts.com/porsche-911-technical-forum/531046-computer-module-repair.html)
Marks996 03-13-2010 09:41 PM
Hi Everyone,
After driving my recently purchased 1999 911C with the check engine light on for the past couple months(Seller convinced me it was O2 sensor), I had local dealer run a diag. Sure enough, not the O2 sensor! Dealer suspects faulty ECM. Porsce wants $5000!
Has anyone had their ECM successfully repaired? I see a few repair/refurb services online- most in FLDA area - they charge around $500 to repair. A little nervous about mailing my cars brain away but maybe worth a shot...
rick-l 03-13-2010 11:06 PM
Find a different mechanic. I doubt he pulled a code that says ECU is dead.
The 996 board might be more help.
scottb 03-14-2010 07:52 AM
Systems Consulting...Automotive Electronics
rick-l 03-14-2010 10:04 AM
That's LorenFB. He hasn't posted here in a couple of years.
86 911 Targa 03-14-2010 11:04 AM
Originally Posted by Marks996 (Post 5235350)
Hi Everyone,
There have been several posts on this subject.
One of the primary failure modes on these unit is a cold or defective solder joint.
rick-l 03-14-2010 11:08 AM
He has a 99 with OBD II. It should tell him exactly what is wrong.
The 996 board may have members with more BTDT experience. He doesn't even know what the code is just $5000.
Marks996 03-14-2010 07:48 PM
Thanks Guys,
I took the car in with a p1531 (Camshaft Adjustment Bank 1 Short To Short), p1123 (Oxygen Sensing Adaptation Range 1 (Cylinder 1 - 3), Lean Limit), and p1125 (Oxygen Sensing Adaptation Range 1 (Cylinder 4 - 6), Lean Limit).
They isolated all the involved components and claim they don't see the computer sending adjustment messages so supect it's shot.
I'm going to call some other garages this week to get 2nd opinion and hopefully find someone local who can test and if necessary repair ECMs. Should be an interesting project - no damn way I'm paying Porsche 5k for a new one!!!
Will let all know how it turns out.
dshepp806 03-15-2010 03:20 PM
another opinion is in order, for sure.
Doyle
rick-l 03-15-2010 09:11 PM
Again I suggest you go to the 996 section and ask there. Also from reading off topic I hear the the dreaded RL may have a good, active 996 section.
I don't have one of those. I have a 88 g50 cab with LSD and 16" Fuchs, the best production Porsche ever made.
