VFR750's Avatar
Wooden Floorboard Repair
I tackled the damaged floorboard today
Trace out the shape of the damaged area and cut it from plywood:
Be brave, and don't look back. Note L30T Hellblau Metallic workbench. I really care about authenticity!
Epoxy it on: (yes a 1/24th 935 in the background. The closest I will get to owning one.)
Add thin fiberglass reinforcement on both sides. See representative piece of glass cloth.
I cut the floorboard as a square cut-out, thinking this would make the glue joint stronger. You'd have to shear one side while bending the seam on the other side. Adding the glass cloth seems like a belt and suspenders thing.
I also used epoxy to glue the delaminated sections together in the area near the drivers left heel. You can see that in the picture. It has already been painted black. A large area was delaminated, all layers. 5-minute epoxy squished into the surfaces, with a thin strip of wood, clamp and wait. Easy fix.
Last step will be to paint it black and seal with clear polyurethane. Seems it is a lot cheaper to fix than replace. Wood and glue were sitting around....
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 03-07-2010, 09:43 AM
Oh Haha's Avatar
Nice job!!
Gotta like a creative mind.
Pacific Blue
Wayne
Old 03-07-2010, 10:30 AM
Is your car a Coupe or targa and what year?
Lorne M.
83 SC
Old 03-07-2010, 12:11 PM
VFR750's Avatar
Lorne M.
82 Coupe
Mike
Old 03-07-2010, 02:46 PM
Thanks Now I know what to look for.
Thanks again Lorne M.
83 SC
Old 03-07-2010, 03:06 PM
VFR750's Avatar
? Looking for a coupe?
Mike
Old 03-07-2010, 03:15 PM
Yes my 83 is lacking both floor boards, got some for sale?
Lorne m.
83 SC
Old 03-07-2010, 03:35 PM
VFR750's Avatar
Sorry, I didn't understand your comment. I only have the set from my car. They are going back in.
Mike
Old 03-07-2010, 03:38 PM
tdatk's Avatar
Went a little different route and used some leftover diamond plate.
Tim
82 SC
90 C2
Yasowatt
Old 03-07-2010, 06:35 PM
micheloaks's Avatar
good repair
like your approach...re: fixing the board.
Consider a type of scarfe joint where both the board and the replacement section have a corresponding bevel where they meet - stronger joint. Also likely to not need glass
reinforcement
Old 05-25-2010, 07:46 PM
HarryD's Avatar
I had a similar failure and used some 0.020 Aluminium stock to make a new tab. Just pop riveted into place.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-25-2010, 08:41 PM
Network Mercenary
I like it
Tom
RIP, 79 911sc
Old 05-26-2010, 12:38 PM
