911 mirrors on 914
I just installed 911 flag mirrors on my 1975 Euro 914. The driver side fit almost perfectly. When I came to install the RH mirror in the same opposite location, I realized that the mirror stand bracket was not the same as on the LH side. Later I realized tha tha 911 did not have the mirrors located at the same spot on both sides.
Does any one know if there is a RH mirror stand that is the same as the LH side? Maybe the UK version? ![]()
Regis turd ab user
As with a left hand drive 911 when you install the right side mirror in the factory cut out it will not be positioned properly because the factory location is for right side drive cars. The mirror you have is fine but you need to relocate where it is mounted.
looks like a nice teener. let's see the rest of the car.
'63 356 S90 Ivory/Red '70T coupe Burgundy/Tan '71 914 Canary Yellow '72 Datsun 240Z Orange/Black '65 Chevy C10 shortbed fleetside Butternut Yellow |
I can't relocate RH mirror now, maybe when car needs repaint. I would like to find just the lower stand bracket similar to the LH mirror.
Why? It looks like he can see out of both mirrors just fine as it is. The base doesn't fit the door profile in that position.
Regis turd ab user
And as far as him being able to "see out of both mirrors just fine", how can you determine that from a close up photo from the front of the mirror? David |
I can see fine out of both mirrors. I made a temporary bigger gasket for the RH mirror.
I noticed that on some 911 photos, the RH mirror is not always located at the same position. Does anyone know if there are different stand bracket for the RH mirror? I would like to get rid of larger gasket. Thanks for the feedback... |
abides.
91173124202 - Right side mirror base - Right Hand Drive cars
91173128802 - Right side mirror base - Left Hand Drive cars I can't tell you what the difference is.
Graham 1984 Carrera Targa |
more work as you have to put in a threaded reinforcement plate, but the 928 bases fit much better. They don't use the J hook to attach, they have a threaded screw
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
gearhead
Interesting mod. I've never considered it because I've always been about the chrome on my 914s, but that looks nice. Well done.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
