Need clarification on an SC ROW engine #
I'm looking up engine info for a friend. Here's the number he sent along:
9301061010R I assume this is an SC ROW 939/10 204-hp engine (fitted from '81-'83), but from which year? It presently sits in an '80 ROW SC, which originally would have had a 930/09 engine (188-hp). As far as the "61010R" bit, I assumes this means 6-cylinder, serial number 1010R--does the "R" at the end mean it's factory rebuilt? Or does the "1" after the "6" indicate a certain market or build year? Finally, all SC ROW engines came with air pumps, right? This engine has one fitted. Any errors? |
That's not the engine number, but might be a casting number...
A typical engine number will read: 6310075 Translation: 6 = 6 cyl engine 3 = 911SC RoW 1 = 1981 0075 = consecutive build number |
Yep, that is a casting number. You need to look just to the right of the fan support to find a pair of numbrs, one on the upright, one on the flat
Anyway, turns out he has a '79 ROW SC chassis and engine, the latter of which may have been rebuilt using a later crankcase (based on the 930/10 "R" casting number. |
| All times are GMT -8. The time now is 07:19 AM. |
