My other ride is a C-130J
Sticky Accelerator Pedal (Not A Toyota Issue)
Hi Gang,
I'm working out the final bugs in my 'SC motor Transplant into my 1975 Targa S. The motor is installed and runs well. When I rev the engine from the engine compartment the motor revs and then falls normally to the normal idle speed. HOWEVER, when I rev the engine using the accelerator pedal the motor revs, stays at the high rev for a moment then slowly falls to the normal idle after 4-5 seconds. I notice that when I pull the pedal up manually after revving the engine the engine acts normally (falls to idle as expected). The car had been sitting for 18 years so I suspect something may need a little grease. Any suggestions where I should focus my attention?? Thanks in advance.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Time to rebuild the pedal linkage! It happened to me and then the pedal became
disconected twice and left me stranded. |
Also inspect the bell crank throttle linkage bushings located on the trans.Seems to be a common problem.Our host has replacement brass ones that will hold up better than the OEM plastic ones. Does the car have cruise?Others have reported the cable hanging up the throttle plate as well.
86' Euro M491 Targa |
The original SC motor had cruise but I did not install it in the '75.
Pedal Rebuild? Seems Logical. Time to research the topic. Thanks
