Rear Shocks loose
Hi, while my engine is out I thought I would do a quick check on all the suspension components. I found the bottom mounts of the rear shocks to be loose. Now I know where the clunking was coming from. I just put these in a few thousand miles ago. I'm wondering if I'm missing a special washer or anything. Starting from the inside I have the bolt head, a large flat washer, the shock and then a special locking nut. PET shows a washer that I don't have under the nut. Is this a lock washer, flat or other? Should I have replace this nut with new?
thanks, Joe
Old 03-18-2010, 06:31 PM
Oh Haha's Avatar
What year/model car are we talking about?
The SC/Carrera shocks use a bolt, no nut.
Pacific Blue
Wayne
Old 03-18-2010, 06:53 PM
1973
Old 03-18-2010, 07:00 PM
MBAtarga's Avatar
Maybe they weren't torqued to spec upon installation?
Mark
'83 SC Targa - since 5/5/2001
Old 03-18-2010, 07:45 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
if i remember it was a flat washer just smaller than the rubber bushing.
hope that helps
ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 03-18-2010, 07:48 PM
