-   -   What is this bracket for (http://forums.pelicanparts.com/porsche-911-technical-forum/531872-what-bracket.html)
robotman 03-18-2010 02:52 PM
Can someone tell me what this bracket is for, its spot welded to the rear deck about where the rear speakers sit.http://forums.pelicanparts.com/uploa...1268949071.jpg
dtw 03-18-2010 02:54 PM
That is where the luggage retaining strap brackets mount up - it should have a mate on the other side of the rear deck. The rear deck upholstered panel is sandwiched in between them. You should see two similar sheetmetal brackets mounted vertically in the rear passenger footwell.
tangerine911S 03-18-2010 02:55 PM
Rear parcel shelf clips into it I think. Also the mount for luggage strap tie-down
robotman 03-18-2010 03:01 PM
ok so it has no value other than a support for something or tie down?
Its not needed for mounting the vinyl cover on the rear deck?
tangerine911S 03-18-2010 03:20 PM
I thought the rear shelf clipped into it but on second thought I think there is something else there for that purpose. The luggage tie downs bolt to that through the parcel shelf. You can grind it off if you dont want the luggage tie downs but they also help hold the parcel shelf down.
porschenut 03-18-2010 03:33 PM
The rear shelf clip holder is actually on the vertical face between the seats. Those in the picture are the luggage hold-down thingies.
robotman 03-18-2010 03:33 PM
My parcel shelf just lays on top of these brackets with no way of connecting or sliding into those brackets. So i guess i could grind them off while im in for these rust repairs.
