Identify This Switch or Sensor please
Hello everyone, SmileWavy
can you tell me the name of this switch or sensor? thanks. http://forums.pelicanparts.com/uploa...1269011163.jpg |
That's the oil pressure switch - PN for my 87 was 911-606-230-00-M85
On Edit - it is NOT the Oil pres switch. |
If it is for your 84 3.2, it would be a temp switch # 930 606 117.
opps, ya, for my 84 3.2
thanks. |
Along with that temp. sender, you may also want a new gasket for the breather cap, a new O-ring for the thermostate next to it and a new oil pressure switch which is the ground for the oil warning light in the dash.
The last 3 items are usually replaced when the engine is out. :) |
Oh man - My bad - The Oil Switch is clearly visible a few inches over and down (forward).
Sorry to for the bad info. |
I would advise changing the fuel lines and intake gaskets with the engine out. I see you have a 3.2.
The oil pressure switch and thermostat o-ring probably should be changed, but if they've been changed recently already, they're not that difficult to change with the engine in. On a 911SC, it's an entirely different matter, and should be changed each time the engine is out. |
Get the good, green Viton O-ring for the Thermostat....do not overtorque those thermostat bolts..clean that nasty area REALLY well before removal,..no debris falling inside is a good thing!!!!!!!!!!
Best, Doyle |
+1 on the fuel lines and gaskets, etc. and chuck in a crankcase breather gasket if you do the tstat & oil press sw.
| All times are GMT -8. The time now is 09:06 PM. |
