leak!!but not the engine
my 1990 carrera 4 targa has a slight leak that has appeared at the rear driver side near the jacking point, checked the engine compartment but all seems fine and dry,any ideas
oil lines good to go?
Doyle |
Ditto the oil lines, or possibly a leak at the front fittings that is "traveling" down the line where it drops at the loop under the jacking point.
what is the "driver side" in spain? a right side jack point area leak is usually related to the oil tank hoses.
Transmission overflow.
You can jack the back of the car from the botom of the engine, and put jackstands under the torsion bar caps. Then you could crawl under and have a look. I like to pad the jack.
My '92 had a horrible leak in front of the right rear wheel. It was the oil hoses. When I replaced them they were so brittle, when you bent them the rubber portion snapped in half.
Not a fun project but certainly necessary. |
| All times are GMT -8. The time now is 03:59 PM. |
