-   -   Recommended Setup for Engine Drop (http://forums.pelicanparts.com/porsche-911-technical-forum/531973-recommended-setup-engine-drop.html)
TronCarter 03-19-2010 08:46 AM
I have wanted a 911 for about 30 years now and am finally at the point where I might be able to afford a project.
I have rebuilt many non-Porsche engines in my life, but they were all the type that can be pulled with a cherry picker. I don't currently have a lift, but will factor that into the overall budget. Can I get some recommendations on what I would need for a lift and rolling scissor table (or whatever you recommend) to drop an engine?
Tron
Tom '74 911 03-19-2010 08:51 AM
Tron -
While a lift is nice, it is not necessary. The first 3+ times I dropped my engine I used (1) floor jack, some jackstands and some blocks of wood under the jackstands to get the rear high enough in the air to slide the motor out once it was on the ground. It's pretty simple actually. If you have a cherry picker, you could use it to help raise the rear end too.
Good luck w/your project!
signature65 03-19-2010 08:53 AM
Second what Tom says.....I dropped mine with a floor jack too. Made an engine dolly with some plywood and castors. Its really very simple to drop these engines.
GaryR 03-19-2010 08:59 AM
While you can do it w/o a lift, a proper two post lift will make your life SO much easier if you have the $ and room for it. I use an 4 wheel ATV jack (Sears?) and simply lower the lift to put the engine weight on it, unbolt, and lift the car while slowly working the engine back to clear the transmission rod from the tunnel and then up she goes leaving the engine/transmission on a rolling platform.
emcon5 03-19-2010 09:48 AM
Lets set the wayback machine to December of 2001:
http://forums.pelicanparts.com/porsche-911-technical-forum/53729-engine-drop-question.html#post346816
euro911sc 03-19-2010 09:53 AM
LOL :p :p :p :p
no lift here either... I do run the front up on ramps so the car angle is not very steep. I also have several 2x12x16 planks I put under the 6ton stands of the rear... its cake...
-michael
Gunter 03-19-2010 11:15 AM
This subject has been covered ad nauseum at least once a week for many years and many, many posts are available.
Use the search button on top for "engine drop" and you'll be rewarded. :)
