| Marc Bixen |
03-20-2010 11:10 PM |
OK guys picky, picky, picky. You can also leave the 6V wiper motor in and install an in-line resistor to lower the voltage to it. Yes you can run a 6V starter on 12V but!!!! Right is right, and you can remove the flywheel, have the teeth machined off and have a correctly toothed (yes there available) ring gear pressed on.
THAT SAID, I wasn't writing a step by step manual on how to convert, I was only giving a general outline that this is not an easy conversion process. You can write a book on the proper way to convert a car as per original 1965 specification. I'm not going there. It was just to help the new guy realize that this is a time consuming, pricey, and generally unnecessary upgrade. That's all, no more no less. But thanks for everyones input.
:cool:
