New garage and lift...
Before -
(1) car parking, (1) 60 watt light, (1) outlet. ![]() After - (2) car parking, (1) 9000 lbs lift, 48 ft of light (+an extra 200 watts), 6 gallon 200psi compressor, (8) 110v outlets, (1) 220 outlet.
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s Last edited by porsche356a; 04-19-2010 at 12:18 PM.. |
Very nice! Looks like a nice roof top patio makeover too!
Sweet!
Awesome.. most people wouldnt think to do this. I hope you arent tall though
JP '76 911s Ice Green Metallic bone stock |
![]() I lowered the lift to get a good pic of the '58. It is 6ft clearance when fully lifted.
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s |
Good, cuz I wouldnt want to pull that expensive pcar in with it that low.. Id have a nervous breakdown each time.
VERY nice!
Are you around Seattle someplace?? The whole pic looks very northwesty, I only say so as I live in the north end of Seattle. e
http://www.autoforeignservices.com/ 57 Speedster, (4) 67S coupe's, (2) 67S targas, 68L Rally car etc. etc. |
DUH...
Just figured it out. Very nice Seth!! cheers, Eric
"farking Porsche hero"
Brilliant solution!
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
what kind of lights did you go with? Getting ready to start my garage renovation next month. Just added 60 additional amps 110 and a 220 outlet.
1981 911 SC 7 & 9 Fuchs, monoballs, 22/27 t-bars, 19/22 swaybars, M&K dual in/ dual out |
R&D guy
Location: the border between the states of inebriation & confusion
VERY nice makeover.
I've been going back & forth myself about purchasing a lift, and my garage is also a narrow one (although quite long). Can you provide any layout drawings of the garage that shows the location of the lift feet & posts, along with the clearances? Thanks, -Dan --------------------------------------- black/black '87 sunroof coupe w. f/r spoilers, Fabspeed premuffler, Dansk 1-in-2-out, SW chip, euro ride height, bump steer kit, bumperettes removed, CDR-220, etc. |
I'll get some measurements and pictures this week. It is tight side-to-side, and front-to-back, but functional. I did raise the roof to to get the clearance I wanted.
The trick is to mount them in the proper place. Take you height, add 6". This will give you good directional working light, but you won't smack into them as you move around.
