2002 996 C4S
Lsd?
What's required to upgrade an non-LSD 911 (in my case '84 911) with a 915 to LSD?
jcsjcs Have: '02 996 C4S Had: '87 944, '84 911 Carrera Targa |
gearhead
In addition to the differential itself, you will need to reset the preload and backlash on the ring gear when you install it. Not generally something I recommend as a DIY job as it requires some specialized tools and expert knowledge. Most shops will bill 4-6 hours for the job.
It's cheap insurance to get new carrier bearings at the same time. Sidecover and axle seals go without saying. And 2 oil changes worth of oil if it's a brand new LSD. There is a break-in period and you'll want to change your gearoil after 1000 miles or 1 track day, whichever comes first.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Would this be for a Quaife?
2002 996 C4S
Sorry guys - but i am a novice when it comes to LSD and many of the components in my car.
I am in the process of dropping my engine to remove the transmission - as I need it rebuilt. What specifically do I need to have done if I want to upgrade to LSD? 1) Change the Differential? What's the cost? 2) Have changes made in the 915 transmission? I know you probably answered in one of the replies above - but I don't quite get it yet. Thanks for the help. jcsjcs
