Carlo A
Guest
Posts: n/a
Leakdown test
What are the chances of bending valves during a leakdown test? motor is a 73RS.
Old 11-30-2001, 12:38 PM
None, if the engine was running correctly before (no bad tensioners, chain ramps, etc.) and the cams and timing chains are left undisturbed. Did your engine get damaged? Jim
Old 11-30-2001, 12:47 PM
What can happen is a piece of carbon can break loose (taking spark plug out and installing leakdown test rig can cause this) and keep a valve from closing properly and thereby producing poor leak down numbers. Jim
Old 11-30-2001, 12:50 PM
what the heck kind of a test are you running on it?
206 637 4071
Old 11-30-2001, 12:58 PM
Carlo A
Guest
Posts: n/a
leakdown
thanks for the input! motor runs strong. it's in my daily driver 72S. a friend of mine is interested in the motor pending a leakdown or compression test.
Old 11-30-2001, 02:10 PM
Carlo A
Guest
Posts: n/a
leakdown test
What I was worried about is if the pressure is applied during the leakdown test, is there a chance that the crank can move against the normal direction of rotation and bend valves? thanks.
Old 11-30-2001, 02:19 PM
The pistons and valve train move together in synchronization, forward or backward, nothing will hit as long the valve train is intact and assembled correctly. Jim
Old 11-30-2001, 02:28 PM
