1967 rocker for 911 s ?
Hi ,
I'am looking for a pair of rocker for my 1967 911 s.
That piece is no longer available by Porsche ..... you can only find the narrow one(T model)
So , i'll try to built the pair .
Can anyone give me the dimension of the metal and rubber piece : width , length , anything I can use to make new one.?
Many Thanks
Laurent
Old 03-21-2010, 12:42 AM
ttweed's Avatar
These are indeed unobtanium. The last set of NOS ones I saw offered in 2008 were $2800 USD.
There was a fellow on the Early S Registry who was going to reproduce the S side deco metal extrusion, but I don't know if he ever did. His name was Lawrence A. Greenberg and was asking $400 for a pair of extrusions, unfinished.
The metal trim is 25-27mm wide, IIRC, and the length is about 130mm shorter than the distance between the front of the torsion bar cover and the front wheel well arch, measured at the height of the center of the torsion cover. See this thread or do a search there on "'67S side deco" or "rocker deco." I think repros of the rubber trim pieces are still available, but of questionable quality.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 03-21-2010, 02:00 PM
