engine lid cover
Problem with '86 SSE. Got the car back from the paintshop after a small job and the pull for the engine lid was only pulling fresh air. Anybody got any idea how to open the engine lid so I can effect necessary repairs
Old 03-15-2024, 11:17 AM
Bill Douglas's Avatar
Umm, my SC's engine lid latch is a "fail open" mechanism. Meaning that if the wire breaks or falls out the latch is open. Have you tried a big shove, wiggle, lift, swearing?
Old 03-15-2024, 12:05 PM
If cable broken or came undone, try pressing the lid down and shift the lid to the right might free up the pawl that normally would retract to the left. You could also try to curl the lower end of the lid to get the pin to release if it was installed too low.
How are the gaps aligned will be telltale sign.
If cable isn’t broken then the pawl (catch) might obstructed and you’ll need to be creative in manipulating the lid.
Old 03-16-2024, 07:59 PM
Registration looks British, so it may be RHD? In that case handle and cable would be on the right of vehicle and shifting the lid to free it up would have to be to the left instead of right as suggested above? Just a thought. Pic is not big enough to see on which side the catch is.
Gilles
RoW 88 Carrera coupé
Old 03-17-2024, 04:17 AM
The release handle is on the left on RHD cars. If it's pulling fresh air then I would expect the cable to come right out, otherwise it is still connected to the lock. It needs one person pulling on the handle and another working the lid.
Roy
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 03-17-2024, 05:12 AM
Ok thanks for the info.
Didn't know that the release handle is still on the left (passenger side) for RHD.
Gilles
Old 03-17-2024, 05:26 AM
proporsche's Avatar
the safety for the rear decklid works like this..remove the T handle and the cable should release the pressure on the latch.But..is your cable rusty? Any history of adjustment-which is very important.
Try it 1st (th handle)and report...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-17-2024, 06:01 AM
