Ride Height
On the front of my 86 911, I put 225/50/16s on 7s and have some rubbing issues. I rolled the fender just a little where it was rubbing, but still no luck. I then raised the car slightly by 1/4 inch and that solved the problem. The front now sits at 25.5" and the rear is at 26.5. This car is a street car, but does some duty on the track...are there any issues I should be worried about. I know most people try to lower their car, but seems as though I had little choice.
Some history here...I replaced my rear boge shocks with Bilstein sports and that raised the rear by 1". I then replaced my front struts, also with Bilsten sports, but ride height didn't change. Thanks
86 Targa |
Where are you measuring the height at?
Yes, the rear should measure slightly lower than the front, which is due to the front fender shape. A common setup is 25.5" front and 25" rear, as measured ground to fender lip. It sounds as though your rear could come down a bit. Be warned that when you start messin' with ride height settings the corner balance and alignment will get out of whack requiring an alignment.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Using center of wheel cap as a guide, measuring from floor to bottom of fender lip. Took car out, still drove straight, felt the same. Haven't touched rear settings. Guess I'll have to keep an eye on the tires to see how they are wearing.
86 Targa |
Unless the rake is like a 72 Nova with Gabriel Hi-Jackers, I wouldn't worry about it.
Keep an eye on tire wear and adjust the settings if needed.
PICTURES
what a ride height ??????????? without a picture straight in from the side and a front corner shot down a side will do just fine ........ also the tail /rear photos are very popular .........also the better half or cute assistant always welcome in the shot ........................ |
I just replaced the worn out Boge strut inserts and rear shocks on my '86 with Bilstein HD. Although at first I didn't think it sat any higher, after living with it for a few days I am not so sure. The non-scientific measurements at the top of the fender are: LF- 25 3/4"; LR- 25 1/2"; RF- 25 7/8" & RR 25 3/4. Whaddaya think, is a lowering and alignment in my future?
Thanks. Mike ![]() ![]() ![]() |
Northern Motorhead
Mike,
I would guess that you're in need of some lowering ... The front is pretty easy,although the rear is a different game altogether ! Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
I vote yes but I like your very clean wheel wells.
rally height is highly underrated
you should drop a it it looks a little high very nice car , dont take the first comment wrong Last edited by 80-911SC; 03-20-2010 at 05:52 PM.. |
I never really noticed how clean the wheel wells are until I washed the car today. I will make some calls on Monday and see what kind of money I am looking at to lower and align.
Thanks for the comments. Mike |
wannabee wannabee
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
Somatic Negative Optimist
Considering that the SC and Carrera came with 15" stock 6's front and 7's rear with 16" being an option, it's not surprising that issues arise with cleanrances when going wider and bigger.
Side-load on the front spindles increases plus a bunch of other dynamics change adding stresses. I am sure that performance doesn't get better by going bigger; I suspect it's just for bling. With 205/55 on 7's in front and 225/50 on 8's in the rear plus Euro height and mildly aggressive cambers plus corner balance, I am very happy with handling.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() Last edited by Gunter; 03-21-2010 at 10:58 AM.. |
Southern Class & Sass
Are there any concerns? Baring the previous mention that your corner balance and alignment changed some, no.
Can the car sit lower? Sure. There are two variables that affect how well those 225/50s will fit. How much negative camber you've got, and how much you rolled the fenders. Mine's set at 24.5" front and 23.5" rear, running 225/50 and 245/45 16" tires. Here's a photo. ![]()
Dixie Bradenton, FL 2013 Camaro ZL1 |
wannabee wannabee
I like better performance and bling. Oh I plan on going down to 16 inch blings.
I'm here to cause trouble
I read somewhere that if you put a degree level on the door sill, you should measure a downward slope of .... someone help me out here... I don't recall what it was....
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
Taking it apart is easy
The rake should be 3/4", according to the Ray Scruggs alignment book.
Jerome Sorry, you my be asking for the degree of slope. Can't answer that. Last edited by Jerome74911S; 03-21-2010 at 02:50 PM.. Reason: incomplete |
Went to the track this weekend, I still had major rubbing issues with my left tire, gouged a nice groove along the side of my new 888, left tire also showed some signs of rubbing. Rolled the fender so that it was flat against the inside fender and that helped a lot, but still had some more minor rubbing on the left side only, I think fenders need to be flared a bit. Probably would help if I wasn't running stock suspension...no issues on the way home, so at least I know I'm good for the street.
BTW, running new 888s and bilstein's all around, the car really runs great, of course, can't keep up in any way with 100k beemers and GT3s ![]() ![]() ![]()
86 Targa |
Camber will help you big time. I run 225's on front and 255's in back on my pretty low '84 and have no rubbing issues now that my camber is -2.1 degrees in front and -2.5 degrees in back.
Here it is during hard braking. No rub.
What is the typical charge for a height adjustment and alignment?
Thanks. Mike |
