2002 996 C4S
jcsjcs's Avatar
Lsd?
What's required to upgrade an non-LSD 911 (in my case '84 911) with a 915 to LSD?
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 03-23-2010, 09:49 AM
gearhead
In addition to the differential itself, you will need to reset the preload and backlash on the ring gear when you install it. Not generally something I recommend as a DIY job as it requires some specialized tools and expert knowledge. Most shops will bill 4-6 hours for the job.
It's cheap insurance to get new carrier bearings at the same time. Sidecover and axle seals go without saying. And 2 oil changes worth of oil if it's a brand new LSD. There is a break-in period and you'll want to change your gearoil after 1000 miles or 1 track day, whichever comes first.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-23-2010, 10:00 AM
Would this be for a Quaife?
Old 03-23-2010, 10:55 AM
2002 996 C4S
jcsjcs's Avatar
Sorry guys - but i am a novice when it comes to LSD and many of the components in my car.
I am in the process of dropping my engine to remove the transmission - as I need it rebuilt.
What specifically do I need to have done if I want to upgrade to LSD?
1) Change the Differential? What's the cost?
2) Have changes made in the 915 transmission?
I know you probably answered in one of the replies above - but I don't quite get it yet.
Thanks for the help. jcsjcs
jcsjcs
Have: '02 996 C4S
Old 03-23-2010, 12:37 PM
