Dr J's Avatar
Innovate LM-2 Pinout
If anyone has an LM-2, can you tell me which is pin 1 in the power connection? The manual gives the pinout but it doesn't show which pin is #1.
Alternatively, if you have an LM-2, can you plug yours in oriented as in this picture and tell me the voltages on the pins? Two pins should be 12V and two ground.
Upper left = ?
Upper right = ?
Lower left = ?
Lower right = ?
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 03-24-2010, 06:07 PM
The upper and lower left pins are ground. The upper and lower right side pins are +12V. Must be making a hard wire power connection. I used a connector from an old PC I had.
Old 03-24-2010, 06:51 PM
Dr J's Avatar
Thanks! I may need to make one up since I can't find my cigarette plug connector at the moment but don't want to delay testing.
Old 03-24-2010, 07:22 PM
