-   -   2.7 CIS won't remain stable - HELP (http://forums.pelicanparts.com/porsche-911-technical-forum/5331-2-7-cis-wont-remain-stable-help.html)
Clark Griswald 05-15-2001 06:21 PM
My 77 with 2.7 with CIS has had a long running problem that has become unliveable.
The car will develop a flat spot around 2200 rpm, to the point of making driving uncomfortable, and it will be difficult to start - requiring 3 or 4 attempts to get it running. The solution has been to adjust fuel pressure and/or replace the warm up regulator.
Used to be this would last for 6 months or more, then slowly detoriate until I had to have my wrench adjust again. Most wrenches would conclude it was a bad warm up regulator (WUR). I went through several WURS over the years and I suspect this was mis-diagnosed.
Eventually the deterioration began happening faster, and it now takes about 2 weeks. I followed the Pelican tech article about modifying the WUR to make it adjustable, works great. But having to adjust it every 2 weeks is out of control.
I think that my fuel pressure is not stable, drifting over time. My adjustment to the WUR is simply compensating for some other problem. I don't have a means of measuring fuel pressure so I can't be sure.
Anyone have ideas on what might be causing this and how I can track it down?
Chuck
'86 Cab, '77 Targa, Family Truckster
critter 05-15-2001 07:39 PM
Clark;I really think you need to find a way to measure your fuel preasure as it sounds to me like your warm up regulator is compensating for a weak fuel pump or possibly a plugged fuel filter.I don't know about porsche fuel tanks but I have seen more than one fuel tank that had started to go bad and kept plugging filters.I think you can get a cis fuel pressure tester at JC witney for like $50.00
Grant 75 911s targa
wckrause 05-15-2001 07:54 PM
I agree, you just can't trouble shoot a CIS system without a fuel pressure tester. Bought mine at JC Whitney for $50. Also bought the Probst book on Bosche FI. It has procedures for testing individual components and for trouble shooting problems. The early CIS systems without the O2 sensor aren't that complicated.
Bill Krause
'79 911SC Euro
Superman 05-15-2001 09:08 PM
I suspect contamination in the fuel too. Rust. That's my suspicion. You should perform an autopsy on parts you remove, especially the fuel filter.
'83 SC
Clark Griswald 05-15-2001 09:16 PM
I have to admit I am way overdue on a fuel filter change, I hang my head in shame. I will try this tomorrow if I can get one locally. That would explain why the problem has gotten progressively worse.
The fuel pressure guage is probably a good investment.
Chuck
Jens Wendorff 05-16-2001 12:56 AM
I agree with the others, and esp. suspect the fuel pump. Have made the same experience as well as other guys (there was a similar post recently).
Jens
Clark Griswald 06-23-2001 05:15 PM
I replaced the fuel filter, and it has been about 1 month now. The car has been stable and consistant in performance the entire time. The fuel filter fixed my problem.
To say that I am elated is a massive understatement.
This problem has plagued me for years. I have had several wrenches look at it, charge me big bucks, and never fix it. More than once I considered selling the car just to get rid of this problem. The car has sat in the driveway for extended periods because of this problem. I might not have bought my Carrera if it were not for this problem.
All for a lousy fuel filter.
So what have I learned? Don't skimp on routine maintenance. I sure didn't save money this time.
I am also wondering why these wrenches didn't find the problem.
I also have learned to value the collective knowledge of this board. You guys are great.
http://www.pelicanparts.com/ultimate...s/frontwsm.jpg Chuck Moreland '86 Cab - "Sparky", '77 Targa - "Sweet Pea"
[This message has been edited by Clark Griswald (edited 06-23-2001).]
