not_sure's Avatar
Question Rebuilding 911 Calipers
Well, my car has been pulling when I would brake, so today I thought I would pull the pads and see whats up. When I got the pads off I see the seals are jacked up pretty bad (thats where that brake fluid went). I pulled the caliper off already and started to clean it up. Is there any other way then acompressor to get the pistons out? Anything special I need to whatch for? I read the tech article and it seems pretty easy to do. I have the aluminun calipers, does that make any difference? TIA...
Tom
71T
http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=173
Old 12-01-2001, 03:32 PM
stew's Avatar
caliper rebuild
be careful when using compressed air to remove the caliper pistons as they can become projectiles. just use air slowly. I had my fingers in the wrong place and got hit by the piston on it's way out.
Old 12-01-2001, 03:52 PM
Early_S_Man's Avatar
Porsche Crest
Tom,
If you are very careful. take one pad out at a time, and pump the pedal slowly ... until the pistons contacts the rotor. Put a folded shop towel under each 'bare' piston after you take the pad out, and don't put much pedal pressure on the system while trying this extraction method. An assistant would help, so you can 'watch' the pistons! Then remove the calipers, and the pistons will be mostly ready to come out for cleaning.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-01-2001, 03:54 PM
not_sure's Avatar
Will I be able to get the rebuild parts from the dealer? I would love to give the sale to pp, but I need to get the car back on the road since I sold my truck and now use the 911 for my daily driver.
Tom
71T
Old 12-01-2001, 04:14 PM
not_sure's Avatar
Warren. Did I read that you recomended the metal master pads? Since I am doing all of this I will replace the pads as well.
Tom
71T
Old 12-01-2001, 04:29 PM
Porsche Crest
Tom,
Yes, I have used and recommended Metal Masters for over 20 years with no complaints ... on VWs, BMWs Mercedes, and my 911!
Warren Hall, Jr.
Old 12-02-2001, 10:48 AM
JDaniel's Avatar
I used the Porsche Air compressor that comes with all Porsche cars (lol). There's neat little plastic adaptor the fits right into the brake line at the caliper. A few seconds and "pop" out comes the piston... Be sure to use a small piece of wood between the pistons, and keep your fingers out of the way!
Dan Tolley
1987 911 Coupe
The Owner's Gallery
2006 Audi A4 3.0q Cabriolet
2003 Ford F-150 XL Lumber and Trash Hauler.
Old 12-02-2001, 12:27 PM
calipers
Warren's way for stuck pistons and Tom's way when pistons are not stuck.
steve
___________________
Steve- 62 356 S90 Sunroof-sold 11/16
73 911 No longer Targa-3.2L Running GT4
88 Carrera G50 sold 2019
2015 Cayman GTS
Old 12-02-2001, 01:01 PM
Clark Griswald's Avatar
Here is another technic for getting stuck pistons out:
I used an extra section of break line obtained from a local auto supply.
Here is a link to my brake rebuilding experience.
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=8623&highlight=project+little+red
Clark Retired, I'm now posting under my real name
Chuck Moreland
Day Job - Elephant Racing
Basic Transportation - '86 Cab - "Sparky", '77 Targa - "The Peaper"
Old 12-02-2001, 01:13 PM
Send a message via Yahoo to tmctguer
i suggest you patent your bicycle pump design before it ends up in the "special tools section" of Performance Products catalog for $250.
Old 12-02-2001, 06:03 PM
