A/C Questions
I have just replaced the condensor and dryer on my 88 Carrera, since the old condensor had a leak when I tried to have the system charged. Would it be a good idea to also replace the O-rings on the other connections (front condensor, evaporator ...) while I am at it, or should I just leave well enough alone, since they were not leaking at the previous test? I also wonder if, by putting in new O-rings, I might just create a leak where there was none before.
I also put in a new front condensor blower (and fuse harness!), since the old one was missing. I had a hard time getting it in place, because it jammed up against the battery on one side (it is a "long" battery) and the front of the fuel tank at the rear of the blower. I had to bang it in with my fist and screw it down to force it into place. Has anyone else had this problem? |
Replace the battery, sounds like you have the wrong size. Mine goes in and out easily, bangin not recommended.
Dont disturb the evaporator just to replace o rings. Don't open any parts of the system just to do "might as wells". You might create leaks. That is the low pressure side of the system anyway.
------------------ Robert Stoll 83 SC 83 944 |
Hello
Yes some batterys are a thight fit and will scratch the fueltank during pulling them out. The 88 AH or larger needs to remove the condesor blower. I wouldn´t touch the sealrings as long they are not leaking or you go to R134a upgrade. The old front condensors are mostly corroded and weaked by vibration. A slight twist can give you the blues. Grüsse |
| All times are GMT -8. The time now is 10:04 AM. |
