SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
RSR bumper grill options
Its time to cut hole for the cooler. Lemme see some pics of what you guys did for a screen?
Home depot stock? or other suggestions welcomed. Mounting options too.
TIA,
Scott
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 03-30-2010, 09:50 AM
MBruns for President
JeremyD's Avatar
http://www.smartracingproducts.com/pdfcat/srp2009_bodyelectrical.pdf
Pegasus - Stainless Steel Wire Mesh
Old 03-30-2010, 10:25 AM
Fast Corners's Avatar
Good use for the Vette.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 03-30-2010, 11:14 AM
porsher
aston@ultrasw.c's Avatar
Your car deserves better than HD expanded metal!
I cut up an engine cover grill:
It is clamped in place with alum nut bars: 1/4 x 1/2 x 7" IIRC
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 03-30-2010, 11:48 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
I am in the process of installing an RSR bumper on my car as well and will be using a modified engine grill in mine. I think it is the sleekest looking alternative, will hold up well, and it matches the rear grill.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 03-30-2010, 01:26 PM
porsher
Mounting ideas:
1. Make two simple right angle brackets and bolt to the front of the tub.
2. Take 2 pieces of alum plate 4 x 2 x 1/4 and loctite a stud into each. Bond to the underside of the bumper so the studs line up with the holes in #1.
3. This is the clever bit hang the bumper on the brackets by the studs. It will flop around a bit but it will hold the bumper in place while you work on the other monting points - making it a one man job.
4. Bond 2 more stud plates to line up with the stock bumper brakets adjacent to the head lights.
5. Mark through the holes in the sheet metal and drill the upper surface of the bumper.
Note that the centerline of the cooler aperture is not aligned with the center line of the car. It's off a bit. At least mine was and based on pics the RSRs were as well.
Second clever bit. If you find that the top edge of the bumper does not fit snug against the hood all the way across, you can slot the holes in #1 to give a small amount of adjustment.
Measure once, cut twice
79 928 Race Car
Old 03-30-2010, 02:47 PM
