michaelw's Avatar
Frequency of oil change/valve adjust?
Hello everyone. Well I am going to take the week off I have over Christmas and start fiddling with my engine. First is to figure out why my car is puffing black smoke. (O2/head temp sensor) Then I will change oil and adjust the valves. Question is, how often does everyone change oil/adjust valves? It's been about 3500 miles since last adjust/oil change but they sure are noisy already.
Thanks,
Michael
87 Targa
Old 12-03-2001, 04:58 PM
Senior Member
Doug Zielke's Avatar
Valves noisy at 3500 mi?
I'd suggest something (wrong) is going on with your motor if a valve adjustment only lasts that long. Also, your guides may be worn, and that is contributing to the noise you're hearing. Either way, you need to check out why this is happening.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 12-03-2001, 05:33 PM
carnut169's Avatar
15k for the valves, 3-4k for the oil (Mobile1)
Sean O.
Atlanta, Ga.
96 Van Diemen Formula Continental
01 2500HD
Old 12-03-2001, 05:34 PM
rscupper's Avatar
Follow the Porsche service manual if you drive it like a car.
If you drive it like a Porsche do both a bit more often.
If you race it, or drive like you're racing it, do both before and after each strenuous 'event' - or at least check before and do both after.
Cheers
Brian
'73RS (almost...)
'84 944 beater
Old 12-03-2001, 07:02 PM
