Heater Blower Motor
Any good ideas on where to find a cheep heater blower motor for the rear 89 911. I don't want to buy a new factory one because of expense. I only use it a couple of times a year.
Mike
Old 12-02-2001, 12:38 PM
Played around with this one quite a bit for my 87. No Luck - due to the odd-ball graphite bushings set up rebuilders would not attempt. Other posters made reference to a VW blower that would work but no one could come up with a part number or application. I gave up and bought one from Wayne, good service - about $20 buck less than the dealer - but even at $259 it seems a bit steep - especially when all you need is the motor and not the housing or fan.
Most likely your foot well blowers will go next - the news is better there, real oilite bushings. Disassemble, clean, re-oil and your good to go.
Take Care,
Bob
Old 12-02-2001, 01:10 PM
JDaniel's Avatar
I bought a used one for $100. It's not cheap, but better than $250 for new. With limited use it'll probably last another 14 years.
Dan Tolley
1987 911 Coupe
The Owner's Gallery
2006 Audi A4 3.0q Cabriolet
2003 Ford F-150 XL Lumber and Trash Hauler.
Old 12-02-2001, 01:18 PM
Doesn't it also come on by itself to help cool the engine? I think it runs more often than when you turn the heat on. That's why it wears out (oh and the cheap bronze bushings don't help).
Chris.
Old 12-02-2001, 01:54 PM
