911tmaster's Avatar
will these wheels work?
i have a 1970 911T with stock fenders and isn't lowered. will 16x6 wheels fit with low profile tires?
thanks,
justin 70' 911t
Old 12-02-2001, 09:15 PM
Monkey with a mouse
kstar's Avatar
Re: will these wheels work?
Hi Justin:
I have a '72 with stock fenders and no rolling. I now run 16x6 Fuchs with 205/50ZR16 SO3s.
I was running 205/55ZR16 SO2s (on the same 16x6 Fuchs) and getting some rubbing at the leading edge of the front fenders - this rubbing only occured when the wheels were turned at a certain angle.
BTW, I run about 1.5 degress of negative camber at the rear and just over 1 degree of negative camber at the front.
With the 50 profile tires the rubbing is gone. This combo works great and the SO3s are great tires for the street!
Good luck to you.
Regards,
Kurt
Old 12-02-2001, 09:33 PM
911tmaster's Avatar
thanks kurt
Old 12-02-2001, 09:37 PM
