Brake Light Switches
After a little research, it is time to replace the two brake light switches on my 85 911 (brake lights are not coming on until pedal depressed a couple of inches). Forgive the stupid question but, will I need to bleed the brakes once this is done? Thanks.
Old 04-19-2010, 05:21 AM
MBruns for President
JeremyD's Avatar
Yes. Search on the topic - several good threads. The good side is you don't have to remove the MC to replace. The bad news is it a bit of a pisser to get at.
Old 04-19-2010, 05:41 AM
Hi
Targa Me's Avatar
Actually I've replaced those 2 switches without needing to bleed the brakes.
Find yourself a 2x4 or broom handle cut to the right length (sorry, i don't know what that is at the moment); to press the brake peddle about 1 inch, doing this closes off the system and a minimal amount of brake fluid is lost.
Also, if you do bleed the brakes, invest in one-way check valve bleeders, that make bleeding the brakes a whole lot easier.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 04-19-2010, 06:56 AM
gtc gtc is offline
abides.
gtc's Avatar
+1, I've also done it without bleeding the brakes. Also, in case you haven't read about it, you may need to remove the plastic connectors from your wiring harness. The switches were changed at some point, and the "adapter" that pelican's catalog refers to is NLA. Just pop the spades terminals out of the connectors and plug them onto the switches directly.
Graham
1984 Carrera Targa
Old 04-19-2010, 08:35 AM
Make Bruins Great Again
Por_sha911's Avatar
Is it possible to replace the switches without bleeding the brakes? Yes.
Is it better to bleed them? TO be on the safe side, yes. Besides, if the fluid is more than two or three years old you really should do a flush of the system anyway. Why have world class brakes and bad fluid (which equals poor braking)?
p.s. The search button is your friend.
Joe
Old 04-19-2010, 09:04 AM
