racemor's Avatar
Question Fuel injector cleaners - do they work?
I have never been a believer in fuel additives but seem to have a problem with the mfi in my '73 E, an intermittent misfire around 3000 rpm. I realize that I will probably have to get the pump and injectors rebuilt at some point. I have gone through all of the points, rotors, plugs, wires, etc. and still have the problem (although it runs really well now when the misfire is not there). Has anyone ever had any luck with injector cleaners? If so, which ones?
tm
Tom
'18 Carrera T
R #368, S #692
North Carolina
Old 12-04-2001, 08:18 AM
Friend of Warren
The consensus of this group, including me, is that using Techron on a regular basis keeps the injectors clean. As a former owner of a 72 E with MFI I suggest you do some searches for threads regarding the MFI as well as the Pelican tech articles to get ideas about curing the misfire. From what you describe you are no where close to needing a rebuild on your MFI.
Kurt V
Old 12-04-2001, 08:39 AM
not_sure's Avatar
Thumbs up
I second the Techron... Worked great for me.
Tom
71T
http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=173
Old 12-04-2001, 10:16 AM
racemor's Avatar
Thanks! I'll check the archives.
tm
Tom
'18 Carrera T
R #368, S #692
North Carolina
Old 12-04-2001, 10:25 AM
BER BER is offline
BER's Avatar
Porsche Crest
Techron is a very good fuel additive...recommended by Porsche I believe.
I have been using Swepco 503 Fuel Improver in my two 911's for about 15 years with excellent results. Just wanted to offer an alternative. Here's the link to Swepco's info page on their fuel additive:
http://www.swepcousa.com/lubesite/products/h503.htm
Bruce
Old 12-04-2001, 10:41 AM
I am really not into additives for oil or gas, but a bottle of techron made a noticeable difference in my 2.4MFI. Just make sure to change the oil afterwards.
My much newer Toyota (1990) always runs just fine with the additive package found in major brand gasolines. But then I drive many, many more miles in it, and fill it up with fresh gas every week or two...
Old 12-04-2001, 12:08 PM
I understand that if you use Techron it may contaminate the oil and it should be changed. I do this.
However, what about using Chevron gas with Techron? Is the Techroin found in the gas so little that oil contamination does not occur?
Old 12-04-2001, 12:17 PM
tobluforu's Avatar
Buy a bottle of techron. Pour into tank that has only 5 gallons of gas. Run car until almost empty. Fill tank up, drive till empty and change oil. My car ran better after i did this. Will run a little funny with that much techron in it. I also did this in my saab and that car ran great afterwards.
Old 12-04-2001, 01:38 PM
svlTarga's Avatar
Post
I tried redline before my last trip in the car after a recommendation from my wrench. Gas milage is up a little, runs about the same otherwise.
87 Targa
Old 12-04-2001, 01:53 PM
Send a message via Yahoo to tmctguer
racemore -- have you searched the archives for threads on this topic? i had the same problem (hesitation at 3K RPM) and solved it by following the "check, measure & adjust" guidelines for MFI.
if you read MY thread, you'll see every step i followed along the way, and what finally fixed the problem.
Old 12-04-2001, 02:20 PM
