ts
Speedometer trouble 83 911
I posted speedometer problems awhile ago,finally got it into my mechanic a couple of days ago. He checked out everything and the magnet in the transaxle that sends the signal has broken off. He says it is probably lying in the transmission somewhere. To fix it he wants 5,000 dollars he has to remove engine and trans axle. Anyone have another solution?
Fleabit peanut monkey
You need another mechanic NOW. Unless that broken magnet costs $3500, you are on a path to get raped. A professional can R&R an engine in just a few hours total - maybe less. A decent rebuilt 915 is $2500 - complete with functioning magnets.
Unless I am out-of-my-mind wrong - and others will post exactly that, if so - you just need to find an honest mechanic. |
Unless I am mistaked (happens often at my age!) you can pull the covers to the diff and refit the magnets without dropping the engine and box.
Maybe someone can confirm?
Jim Holmes
The spelling goes with age as well.....
Jim Holmes
Mistaked works for me.
Ok, this is what I am thinking see the picture below.
![]() Notice that the ring holding the magnets for the speedo are at the opposite end to the crown wheel. You should be able to drain the oil and pull the diff cover off, after disconnecting the driveshafts of course. I think that when I did mine the crown wheel was directly on the other side of the cover, that being the case you should be able to pull the diff out far enough to clean the area of the speedo ring and refit the magnets (JB weld?) I found my magnets in the bottom of the case with plenty of the original "glue" on them.
Jim Holmes
Senior Advisor
Pretty sure you must remove the differental from the trans. to change this part. It is on the right side and the cover is on the left side. Yo can make sure the sensor is working and in the hole on the right side above and forward of the axle (hope the mech. did this already).
08 Cayenne Turbo Last edited by James Brown; 08-31-2010 at 05:43 PM.. |
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
Jim Holmes
ts
speedometer trouble
Thank you all for the info,very helpful. My mechanic changed his tune a bit but now wants to replace the clutch and is still looking for a big payday. Anybody know anyone in Chicago area?
ts
I read this to my mechanic and he is going to give it a try.
Thankyou very much, tom |
