pcar9119's Avatar
Can I glass bead my Heads?
Last fall, I found 3 broken head studs on the left bank on my SC. I removed the head about a week ago and saw what was happening. Everything looks alright other than some scaring were the sealing ring moved out of the grove in the cylinder and got pinched a few times agianst the combustion chamber in the head. It seams to be relatively light but was wondering if glass beading an aluminium head is safe or not. Thanks.
Old 04-19-2010, 02:20 PM
Senior Member
Superman's Avatar
Yes, I have seen glass-beaded heads. Once they are cleaned up, inspect them carefully. It sounds like they are damaged. If you look carefully on the surface that touches the tops of the cylinders, and if you see that the cylinder has left a mark of any kind, that means your head has been beating agains the top of the cylinder and is no longer flat. I had my heads fly-cut when they were off for a head stud repair.
Mocha 1978 911SC. "Coco"
Old 04-19-2010, 03:49 PM
DUK DUK is offline
DUK's Avatar
Yep, just clean them good with hot soapy water afterwards and then machine.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 04-19-2010, 04:10 PM
pcar9119's Avatar
I don't see any marks where the cylinders have been baning on the heads, just some scaring from the sealing ring around were the ring meets the head.
Old 04-19-2010, 04:32 PM
pcar9119's Avatar
Heres a pic of what I got. I think just a good beading would clean this surface right up. You can feel it with your finger, but it isn't real deep. I'm a machinist so I'm used to feeling .005 differences in surfaces so I can feel it well, but doesn't feel to damaged. What do you guys think?
Old 04-19-2010, 04:48 PM
DUK DUK is offline
DUK's Avatar
I think you're going to take more than .005 off to clean that up. That's what I think.
2000 & 2007 Dobies
Old 04-19-2010, 05:19 PM
those swirlies are from the head gasket inner windings blowing out and getting pounded between head and cylinder. i would recommend having them all flycut. that does not look good. once they're glass beaded, you will see more. then there's the matter of the cylinder top edges that get pounded just like the heads. a good machinist can do a slight cleanup cut on those also, so you get a decent seal all around and no seepage, (fluid or compression).
206 637 4071
Old 04-19-2010, 05:29 PM
David's Avatar
John, is it true that the head sealing face is machined with a slight taper, maybe a thousandth or two?
Old 04-19-2010, 05:35 PM
In my experience when there is broken studs there is a tenancy for the heads to warp and requiring fly cutting as part of the valve job completion.
Bruce
Old 04-19-2010, 06:18 PM
