Question rear torsion bar removal
Trying to remove torsion bars in order to replace bushings. they came out of torsion tube, but refuse to be driven out of radius arms. have tried all the tricks in these archives. Cutting the bars looks like the next alternative. Can they be cut with acetylene? Thanks, Bob
Old 04-02-2010, 05:56 PM
Mark S
Yes a blue wrench is fine, a cut off wheel works well too they are fairly soft.
Old 04-02-2010, 07:49 PM
Chuck Moreland's Avatar
To free a stubborn torsion bar from the spring plate you can do several things:
Spray some penetrating oil into the spring plate such that it reaches the splines. Then hold the spring plate and torsion bar and wiggle them. Wiggle some more.
Didn't come out?
More penetrating oil, then apply some heat to the spring plate outside the splines. Not crazy hot, maybe 150 F.
Wiggle some more. Wiggle again.
Still won't come out?
Drill a hole in the cap at the end of the spring plate tube - at the end of the torsion bar. Then escalate through the following methods to pop the torsion bar free:
1) Put a drift into to the hole and wack it with a hammer.
2) Tap the hole and thread in a grease fitting. Pump full of grease to push the torsion bar out with hydrostatic pressure.
3) Remove the grease fitting, drill to about 1/4 inch. Fill the cavity full of grease. Get a drift that fits snuggly into the drilled hole, insert it. Wack the drift with a hammer. Done properly, this will produce even higher hydrostatic pressure.
4) Tap that larger hole, fill cavity with grease, thread bolt into hole. Torque in a bolt. This produces hydrostatic pressure plus the force of the bolt abuting the torsion bar.
Still doesn't work?
Start cutting.
Chuck Moreland - elephantracing.com - vonnen.com
Old 04-02-2010, 08:31 PM
Recreational User
porschenut's Avatar
You could also try whacking it in the opposite direction (in) to try and break the splines loose. Then maybe you can wiggle it out.
Old 04-02-2010, 08:45 PM
pete3799's Avatar
Steve,
Won't the end cap just get pushed off by the grease rather then pushing out the TB?
A three jaw puller and heat worked for me. I had to get mine red hot before they
broke loose.
Pete
79 911SC RoW
Old 04-02-2010, 08:55 PM
Thanks guys, I'll let you know. Bob P.
Old 04-03-2010, 07:35 AM
I took the cowards' way out After 3 days of flailing heating pounding both torsion bars, I took my grinder, installed a thin cutting disc, and in 5 minutes had both bars cut in half. Now I just have to have the stubs pressed out (?$), and buy 2 new torsion bars- ~$300. But I feel good! Bob P.
Old 04-03-2010, 05:05 PM
Recreational User
porschenut's Avatar
Well, it's not like you didn't try all the alternatives first. Sometimes you just have to punt.
Old 04-03-2010, 05:09 PM
midnight911's Avatar
i know you want a new beefier bar...cut 'em loose... :-)
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 04-03-2010, 06:11 PM
