-   -   Battery cutoff switch on negative terminal? (http://forums.pelicanparts.com/porsche-911-technical-forum/534823-battery-cutoff-switch-negative-terminal.html)
whackit 04-03-2010 02:28 PM
Hi Folks.
I recently relocated my battery to the smugglers box and hate always having to rummage into there to get to my battery negative lead when I am working on the car. I was thinking of installing one of these hella battery cutoffs pictured below. I know that these are traditionally wired on the positive side of the circuit. Does anyone have a reason why I shouldn't wire one in on the negative side?
Thanks.
http://www.euromotives.com/i/ebay/f/1132110446.jpg
RSTarga 04-03-2010 04:40 PM
Mine is wired on the negative side. I can't imagine why one would wire this on the pos. side.
McLovin 04-03-2010 05:46 PM
Most ferraris come from the factory with a manual battery cutoff similar to that (at least they did all through the 80s).
They are always on the negative side of the battery.
rattlsnak 04-03-2010 05:54 PM
if you never plan to shut the car off when it's running, as in a requirement for a race car or such, and are just trying to save the battery, then it's fine to hook it up on the negative side..
big difference...
James Brown 04-03-2010 06:17 PM
For safety (like racing or fires) wire it up to the POS. side. And if you do, make sure there is a constant power supplied to the ALT. so you don't burn it out. You can also use a relay to disconnect the battery and put the switch where you like to.
